si85rogo
#1 Posted : Saturday, September 19, 2009 9:05:31 PM(UTC)
si85rogo
My TRIO (bottom freezer) refrigerator is only 20 months old. There is a water leak (it has water dispenser and automatic ice maker) below the bottom freezer (within evaporator area/tray). There is no water leaks anywhere inside the refrigerator cabinet (by ice maker or water dispenser). There are 2 water tubes going down to evaporator tray. I temporary shut-off the water supply until I find the problem. Can someone provide the water tubing diagram for Kenmore 596.76594600 (by Amana, similar model is #AFD2535FES) or recommend the possible solutions/repairs of this problem? Thanks.
si85rogo
#2 Posted : Saturday, September 26, 2009 12:05:07 PM(UTC)
si85rogo
I fixed the problem replacing the leaking Dual Water Valve, part #67006531. It's mounted on the rear bottom cover (follow the main water tube for location). Any water leaking refrigerator with automatic ice maker and/or chilled water dispenser may have similar problem (just for other members information).
