amana abb1922feq2. doesn't derost but diagnostics are normal.
Groups: APP Team
Hi. Open the rear panel in the freezer and check the defrost heater and defrost thermostat for continuity (thermostat must be ice cold while tested). If both has continuity - replace the control board. The thermostat Part number: 67003426
