Hy, Im negro, My dryer gets hot but it wont dry, clouse stay damp, I install athermo fuse and the coils but it stay the same gets hot but wont dry,I think that it may be the thermostat but i nee your help,please. Thank you.
Most likely the cause of the problem is a restricted air flow through the dryer exhaust line. Clean it all the way from the dryer back to the vent hood. Remove the rear cover. Remove the lint chute and clean it too.
Originally Posted by: Gene  Most likely the cause of the problem is a restricted air flow through the dryer exhaust line. Clean it all the way from the dryer back to the vent hood. Remove the rear cover. Remove the lint chute and clean it too.
Gene. thank.you gene that was the problem,the exhaust line was cloggedted. thank you. god bless you.
You are welcome. I'm glad you were able to fix it and it was not very difficult.
