My washer will tumble, but not spin. I checked codes it had E47. I followed the troubleshooting guide supplied with my washer. I have checked resistance of coil on door latch it read 1500 ohms. I replaced motor control board and still does not spin. Not sure how to clear stored faults.
Groups: APP Team
Hi.
Check the wire harness and connections between the door latch and control board. If that's OK - replace the door latch. Make sure the water is draining out completely.
Simon..
