elaine40
#1 Posted : Sunday, August 5, 2012 6:31:49 PM(UTC)
elaine40
My dishwasher was working fine but then the water didn't completely drain the last time I used it and no lights come on when you press them. I checked the breaker box and all is good. Not sure what to start checking first?
Simon / APP Team
#2 Posted : Monday, August 6, 2012 12:56:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the unit and remove the control panel. On the side of the control board housing locate the thermal fuse. Using the multimeter check the fuse for the continuity.
If it's open - replace it. Use all wires included in the kit.
Part number: 675813
Part number: 675813
Here are the breakdown diagrams and Replacement parts for Whirlpool DU948PWKB1 DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
