Whirlpool Dishwasher is leaking from water inlet assembly on left side of dishwasher.Water is spurting out the vent holes on the sides of gray assembly.I pulled the black filler hose off and checked for any obstructions but all was clear.I ran DW with the hose into a bucket and it had plenty of pressure (almost to much??) Any Ideas???
Originally Posted by: rmccarthy  Whirlpool Dishwasher is leaking from water inlet assembly on left side of dishwasher.Water is spurting out the vent holes on the sides of gray assembly.I pulled the black filler hose off and checked for any obstructions but all was clear.I ran DW with the hose into a bucket and it had plenty of pressure (almost to much??) Any Ideas??? Hey there, I just pulled my Whirlpool dishwasher out from under the counter yesterday due to a wet floor and found the exact same problem but I don't understand why it is happening. I even hooked it back up in the middle of my kitchen to troubleshoot it and now it does not seem to leak - have you figured out the problem yet?
