Woltato
#1 Posted : Saturday, September 19, 2009 3:16:19 AM(UTC)
Woltato
Washing started making an odd noise when spinning. Took the top off the washer and found it was being caused by a small black rubber pipe that leads from the side of the soap drawer to a small hole in the top of the drum, The pipe had been pulled through the hole and was scraping against the side of the drum shen spinning. I'm guessing this is not a major problem although the pipe is now damaged. does it need replacing and if so is it a simple job to do?
Any help would be greatly appreciated.
Woltato attached the following image(s):
sidfink43
#2 Posted : Sunday, September 20, 2009 6:21:04 AM(UTC)
sidfink43
I cannot get your model number to come up. Please check it
If this is not a U. S. machine we probably cannot help you.
