fridge makes crakling noise when door is open, the lights don't work and the display is not lit. the popping sounds like a short circuit coming from the back. the fridge is still running.:confused: is it the main circuit board?
Hi Gregory, Sounds like the problem is a bad control board on the back of the refrigerator (#18 at the diagram). - The control board Part number: W10135090
Originally Posted by: Gene  Hi Gregory, Sounds like the problem is a bad control board on the back of the refrigerator (#18 at the diagram). - The control board Part number: W10135090
Thank you, Gene, for your help. I just ordered the part and should have it in a couple of days. You guys are great. Thanks again!
