retiree
#1 Posted : Friday, September 18, 2009 11:04:53 AM(UTC)
retiree
We have a kenmore oven model # 79096614400 Serial # VF43660176. The door does not close properly. With the door closed there is a 1/4" cap at the bottom and 1/2" at the top measured from the door to the oven. I've read that the problem may be the hinges. I can not locate my exact model # , so that I know I'm ordering the correct hinge kit. If the problem is the hinges, can you give me the part # , so I may order the correct hinge kit.
