keeg2004
#1 Posted : Monday, July 30, 2012 6:52:01 AM(UTC)
keeg2004
I am attempting a DIY repair to replace display head and relay board in thermador 301 single wall oven. The repair kit that I ordered from appliancepart pros is #702450. to resolve a F24 error code.
The tech service bulletin that I received as part of the order refers to a Bosch home appliances portal that will provide the 'detailed' info to service the displayhead, power board, etc... - however the portal does not work and the Bosch tech support refuses to provide me the info since I am not a certified repair person.
Does any one have this detailed service info that they can send me?
>Tech Service bulletin is 58300000153222 ABZ EN A
Thanks, Mark
jp_austin
#2 Posted : Friday, November 24, 2017 9:01:46 AM(UTC)
jp_austin
I know this is old but did you find a way to access the data? I also have a POD301 oven and it's acting strange. Will shut off after about 20 minutes and the temperature is not well controlled. The "oven on" light fails to come on when the bake and temp knobs are in valid positions.
Guest
#3 Posted : Friday, December 9, 2022 8:06:20 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
E0221 error codes
