linus410
#1 Posted : Friday, September 18, 2009 10:37:08 AM(UTC)
linus410
I got a new rear bearing for the dryer,I lifted the top and took off front panel. I then released the belt from the motor pulley I cannot get the drum to come out,I tried lifting it with the belt it will not come out ,what am I doing wrong?
SublimeMasterJW
#2 Posted : Friday, September 18, 2009 9:01:46 PM(UTC)
SublimeMasterJW
Just give it a good yank upwards or just reach inside and remove the 3 screws holding the drum bearing on.
How replace rear bearing in dryer (Dryer Repair)
by frank5 3/9/2013 6:17:43 AM(UTC)
Rear Bearing (Dryer Repair)
by Imagegenerator 7/14/2012 11:00:09 AM(UTC)
Can I replace ONLY the rear bearing assembly? (Washer Repair)
by jesseservin 1/24/2011 2:10:18 PM(UTC)
Rear Bearings Tourqe setting (Washer Repair)
by handy man maybe 12/20/2010 4:23:52 PM(UTC)
Whirlpool Rear bearing failure in les than 18 months (Washer Repair)
by krandyyy 10/2/2010 2:18:58 PM(UTC)
rear bearing (Dryer Repair)
by gacotton 3/10/2010 10:28:22 AM(UTC)
Rear bearing replacement - Frigidaire (Washer Repair)
by jhicks 2/21/2010 6:19:34 AM(UTC)
Installing Hotpoint Rear Bearing (Dryer Repair)
by Hopefulnow 2/13/2010 4:26:59 PM(UTC)
Frigidaire rear bearing replacement (Dryer Repair)
by Irontrader 2/5/2010 11:22:38 AM(UTC)
by Lawrence00 11/10/2009 10:11:47 AM(UTC)
front and rear bearingrace removal (Washer Repair)
by lylemuhl 10/13/2009 2:05:25 PM(UTC)
Rear Bearing replacement (Dryer Repair)
by Randy Adams 9/11/2009 8:53:49 AM(UTC)
Kenmore Dryer Rear Bearing installation (Dryer Repair)
by kennyhat 4/4/2009 12:58:18 PM(UTC)
Rear bearing on Frigidaire (Washer Repair)
by Kenworth 8/19/2008 3:20:16 PM(UTC)
replacing rear bearing on ge dryer (Dryer Repair)
by ejwtlw-1 1/8/2008 3:47:13 PM(UTC)
