dirtman 13
#1 Posted : Sunday, July 29, 2012 8:06:36 PM(UTC)
dirtman 13
i have a whirlpool cabrio washer that keeps displaying ul code an flashing during the rinse cycle then it stops there. If I lift lid and rearrange the load and push start again sometimes it goes sometimes not and it spills water on the floor. I have cleaned and grease the suspension pivot balls and sockets taken agitater apart cleaned and greased no articles of clothing anywhere motor seem to have plenty of power when it does spin cycle open for suggestions thankls wayne:mad: :mad:
ApplianceJunk
#2 Posted : Monday, July 30, 2012 5:09:51 AM(UTC)
ApplianceJunk
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
➔ Display clears if mini-cycle successfully rebalanced the load.
➔ If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
I have attached a copy of the tech sheet for you.
Is the washer sitting on a solid floor and level?
File Attachment(s):
Tech Sheet - W10026571.pdf (368kb) downloaded 36 time(s).
johnchhan
#3 Posted : Monday, August 26, 2013 10:14:49 AM(UTC)
johnchhan
I Have The Same Problem. Did You Get Yours Fixed? What Was The Issue And How Much Did You Spend?
I Also Have A Cabrio And Leaks Water And Displays Ul Code. It Makes Weird Rubbing Or Grinding Noises As Well.
Guest (4)
