dragz
#1 Posted : Saturday, July 28, 2012 8:28:47 AM(UTC)
dragz
washer doesn't spin or agitate but everything is works normal
i turned/spinned the agitator backwards with my hand and then started the spin cycle and it spins until it reaches a point, then nothing.....
also, how do i open the case on this washer
dragz
#2 Posted : Saturday, July 28, 2012 9:19:35 AM(UTC)
dragz
crazy solution i just found....i took the top control panel off and behind the cycle button there was a red button that i pushed (this has same affect has pulling the cycle button to start/stop washer)......and waaalaaa! ....now it agitates ands spins again
dragz
#3 Posted : Sunday, July 29, 2012 7:43:25 AM(UTC)
dragz
well it stopped agitating and spinning again....after i came home from work, i tried turning agitator with hand and it won't budge even a little....any idea what the problem could be?
washer doesn't spin or agitate, (Washer Repair)
by galarky 7/29/2011 5:00:10 AM(UTC)
