Front load washer. Washer pumps out water, starts to fill then stops and the start button blinks. Checked hoses and they are all clear. Checked strainers at hose inlets and they are all clear. Cleaned out rinse filter. Replaced water level switch. Any suggestions? Will
Hi
I would run the washing machine through the diagnostic cycle and see what happened. The tech sheet with the information how to run the washing machine through the diagnostic cycle can be found inside the washing machine cabinet.
there is no tech sheet inside the cabinet
