My Whirlpool Washer will do everything fine but it won't spin out in the spin cycle unless I twist the tub manually to the left. When I twist tub to the left I twist it until it seems like it tightening something then it will spin out. I'm not sure what to do.
You have a worn out clutch and probably bad brake shoes. Go to my sticky above, "replacing direct drive washer brake shoes".
