late arrival
#1 Posted : Tuesday, July 24, 2012 2:38:01 PM(UTC)
late arrival
it appears that the treads holding the agitator bolt to the trans. is stripped in the transmission. is there an easy fix.
sidfink43
#2 Posted : Thursday, July 26, 2012 3:48:26 PM(UTC)
sidfink43
I assume the bolt is out. If you have or get a tap and die set you may be able to make new threads for either the existing bolt or for a slightly larger one.
Alternatively you may be able to use a threaded insert. Check at a good hardware store.
