1) No water to ice-maker, though it works as it should if I fill tray manually. 2) No water to dispenser. 3) No water at coupling at bottom of freezer door. 4) Water is getting to filter/bowl. 5) Valve sounds like it's activating/working when dispenser is actuated. Is there a connection point, between the filter out and the ice-maker and/or dispenser in, that I could check for water continuity? Thanks!!!!
Pull the valve out, disconnect the plastic lines coming out of it and try the dispenser, if you get water, valve is ok and you probably have a frozen line inside the fridge, if no water out of valve check to make sure there is proper flow from your supply, if that's ok and you still get no water from the valve, then replace the valve.
hope this helps
