I had the oven door of the Amana gas free-standing range explode into thousands of pieces. (Model ARG7302LL & part 316227L) It took me awhile to track down a replacement, as it is now manufactured by Whirlpool; however, I'm not too sure how to go about replacing it, when it finally comes in. Any tips as to how to go about putting the replacement glass into this particular door frame?
Hi Harley, Remove the door from the range. Place the door on a flat surface with the front facing down. Remove screws held the inner door panel. Remove the inner door panel and you should get access to the door handle screws. - Here are the break down diagrams for the Amana range Model ARG7302LLGene.
I just had the same thing happen to My Amana ACS7270AW, but have yet to locate the glass piece. Any help would be Great.
