Cherie
#1 Posted : Thursday, September 17, 2009 3:32:13 AM(UTC)
Cherie
The start switch on my dryer that turns to the right to start dryer was slipping. Now it will not start the dryer at all. I removed the knob & tried turning the whatchamacallit that sticks out with pliers & that doesn't work either. This is very perplexing to me. Do I just need a new knob? This is what my three children look like in the morning when their favorite clothes are not dry enough to wear at a moments notice....:mad: :mad: :mad: . Please help! Thank you, Cherie
kayakcrzy
#2 Posted : Thursday, September 17, 2009 4:24:29 AM(UTC)
kayakcrzy
Originally Posted by: cherie Go to Quoted Post
the start switch on my dryer that turns to the right to start dryer was slipping. now it will not start the dryer at all. i removed the knob & tried turning the whatchamacallit that sticks out with pliers & that doesn't work either. this is very perplexing to me. do i just need a new knob? this is what my three children look like in the morning when their favorite clothes are not dry enough to wear at a moments notice....:mad: :mad: :mad: . please help! thank you, cherie
replace the start switch. or, if it is a 2 wire start switch, take the 2 wires off the start switch, and put the terminal ends together, and then put some tape around it, so the metal terminal ends do not hit metal, and then turn the timer on, and it will come on without the start switch. do this with the dryer unplugged. tom
GE Dryer turning on without using start switch (Dryer Repair)
by Sinanan 8/15/2015 8:28:21 PM(UTC)
Dryer and buzzer won't stop, start switch is ok (Dryer Repair)
by Thorzdad 7/12/2015 12:04:26 PM(UTC)
All LEDs out, only the start switch works (Dishwasher Repair)
by Jimbo Bigbelly 2/11/2015 11:55:12 AM(UTC)
Dryer start switch wiring (Dryer Repair)
by canifixit14 9/5/2014 6:23:39 AM(UTC)
Maytag dryer will not stay running unless you hold the start switch (Dryer Repair)
by J-Bird-Medic 8/28/2014 7:53:06 AM(UTC)
by duckb0y01 3/15/2014 10:11:53 AM(UTC)
Dryer starts w/o start switch (Dryer Repair)
by jhasr 1/28/2014 5:43:38 AM(UTC)
Replace dryer start switch (Dryer Repair)
by Jpcboca 2/25/2013 7:52:09 AM(UTC)
Dryer runs (without heat) only by holding down Push-to-Start switch. (Oven Repair (including Ranges and Cooktops))
by Reinaldo 12/18/2012 7:51:00 PM(UTC)
Dryer start switch won't stay on. (Dryer Repair)
by liebem 9/16/2012 6:06:38 PM(UTC)
Testing Start Switch Continuity- Which Prongs? (Dryer Repair)
by socrjul 5/25/2012 8:17:24 AM(UTC)
Dryer will not start. Need help with 3 terminal start switch (Dryer Repair)
by EDogzz 5/17/2012 6:38:26 PM(UTC)
Rotary Start Switch (Dryer Repair)
by pdl2 4/23/2012 4:46:54 AM(UTC)
Must continue to hold start switch to operate dryer (Dryer Repair)
by ABCh 4/1/2012 8:38:31 PM(UTC)
by debusk 1/29/2012 9:52:11 AM(UTC)
