iamintoit@hotmail.com
#1 Posted : Wednesday, July 18, 2012 1:14:26 PM(UTC)
I have been reading the forum based on my issue and I am hoping to get wittled down to the exact issue. I am getting an LE error code. THe washer ran one load fine then the second load had the LE error code. If I unplug and reset the machine starts to fill (already water in drum) it will agitate in one direction then when it tries to go in the opposite direction it is as if there is no rotating magnetic field. The drum looks like it is in DC lock mode. THen it spins again in the same direction. then it locks again and then I get LE error code. I tested the stator with a DLRO and an LCR meter and it reads 7.77 ohms on each phase and 49 mH inductance with a Q of 9.95 @ 1 kHz & 4.57 @ 120 Hz and it reads 511-512 nf ! 1kHz and 33uf @ 120 Hz so I think the stator is good. The cable at the bottom also has no cracks or wear marks so I suspect it is good also (Plus spinning in one direction means it is getting power).
I need a service manual. Can you send to me. I suspect either the control board or the hall sensor are bad. Is there a test I can perform to test this and find out which I need to buy.
