Hi I have a kenmore model 110.60092991 and the control panel does not work, Or does so intermittently, and when it does work the dryer beeps after about 1-2 minutes of operation .....continuously. There's no noticeable pause between the beeps.
Corel What did you mean saying "the control panel does not work"? It goes blank or it does not accept any command or it stops and shows an error code? I need as much information as possible. Gene.
