bigt81
#1 Posted : Wednesday, September 16, 2009 9:29:15 PM(UTC)
bigt81
installed a new circuit board dryer comes on and now the do code is on and will not go away. How do I check to see where the problem is.:confused:
#2 Posted : Thursday, September 17, 2009 2:47:41 AM(UTC)
Replacement parts for CROSLEY CDE4205AYJ | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
http://www.servicematters.com/m...ibrary/docs/16026775.pdf
Although I could not find it in the info "do" probably stands for door open.
Run the diagnostics to confirm this.
Could be a bad switch, a bad connection or the switch is not being closed by the door.
Always an outside possibility that the board you received is defective.
