Background: Refrigerator was inadvertently turned off when the houskeeper was cleaning it. All ice melted and flowed out to the floor.
I removed all the ice in the ice bin, and let it cycle for a day to fill it up. Not so coincidentally, teh dispenser does not work. I hear no noise at all when the lever is pressed.
I suspect that the dispenser motor is damaged and needs to be replaced. I've looked at parts lists and the exploded diagrams they have but cannot figure out how to remove the motor.
Help.
Figured it out. Just hope it's the issue, the motor is $69.
I have same problem. How did you fix problem? Originally Posted by: jhissong  Background: Refrigerator was inadvertently turned off when the houskeeper was cleaning it. All ice melted and flowed out to the floor.
Help.
