mwurst@hotmail.com
#1 Posted : Wednesday, September 16, 2009 5:32:51 PM(UTC)
mwurst@hotmail.com
No wash cycles will start. We get a flashing "dl" and "f" code. Do you know which control board needs to be replaced? Thanks
sidfink43
#2 Posted : Friday, September 18, 2009 6:18:37 AM(UTC)
sidfink43
This is a fairly new model for which i do not have any technical information. (Since we who respond repair things, we know the older stuff well, but the newer stuff, well, not so well)
See if there is a tech sheet with trouble shooting info and error code info inside the bottom panel. Perform the diagnositics and see if that will help.
I suspect you will find you need a new door lock assembly, and maybe a new CCU. Be sure and check the wiring from the CCU to the door lock assembly for any breaks or shorts as that could also be your problem.
Good luck
savage26
#3 Posted : Tuesday, September 29, 2009 4:15:39 PM(UTC)
savage26
I have made a plastic part that is 18.99 and send it anywhere with instructions.Im not a repairman but it fixed mine whereas the repair guy couldnt.Its not fixed by replacing the panel.Well it will be but thats thesuper expensive fix.Its much easier than that. In roughly 1 year when it goes back again.
sidfink43
#4 Posted : Tuesday, September 29, 2009 4:56:59 PM(UTC)
sidfink43
OK Good
I don't know exactly what you did, or where you did it, but if it works, that's great.
Thanks for the update!
