CWeasel
#1 Posted : Sunday, July 15, 2012 10:03:37 AM(UTC)
CWeasel
Our roper dryer has stopped working in auto sense mode. I'm not sure how long it takes but it will stop before the cycle is over. The cycle knob is still in the same location as when it was started. Appears to be working fine in timed mode. There is good airflow at the back of the dryer and at the vent outside. So my assumption is that whatever sense the moisture has stopped working. Found the parts listing for my model but haven't been able to figure out what is sensing the moisture. Any help is appreciated.
#2 Posted : Monday, July 16, 2012 1:33:38 AM(UTC)
Replacement parts for Roper REX4625EW1 DRYERS | AppliancePartsPros.com
See the attachment for the tech sheet. The closest I could find was an REX4625EN0. Yours should be a close match if not the same.
The unit does not measure the moisture directly in auto modes.
What it does is that timer contacts TM/OR close. The timer motor then gets power through the heating coil when the coil is turned off by a thermostat. The resistor drops the 240 volts down to 120 volts which is what the timer motor requires.
Unplug the unit and set it to mid scale in an auto mode.
Measure the TM/OR timer contacts. Should be 0 ohms.
Measure the resistor. Should be about 4,500 ohms.
Disconnect both wires from the heating coil. Measure the coil. Should be about 10 ohms. Then measure from each side of the coil to the frame. Both should be infinite ohms (open). What can happen here is that the coil can ground and it is running on 120 volts so the timer motor never gets the correct voltage in auto mode.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
REX4625.pdf (126kb) downloaded 186 time(s).
