repondtomehere
#1 Posted : Wednesday, September 16, 2009 11:05:04 AM(UTC)
repondtomehere
Groups ready for retrieval: Registered
Views messages in topic : 2
My oven does not work, but the broiler and stove top do. I read somewhere that it could either be the igniter or maybe the stove relay behind the control panel? Help would be appreciated, thanks so much.
Steve
kayakcrzy
#2 Posted : Thursday, September 17, 2009 4:49:28 AM(UTC)
kayakcrzy
Originally Posted by: repondtomehere Go to Quoted Post
my oven does not work, but the broiler and stove top do. i read somewhere that it could either be the igniter or maybe the stove relay behind the control panel? help would be appreciated, thanks so much.
steve
it is most likely the ignitor. but if you have an ohm meter, check the gas valve first. it is a dual valve. ! set of wires on one side, and the other set on the other side. on one side take 1 of the wires off, and see if you get a reading accross the 2 terminals. if so it is good, if not replace the valve. do the same test on the other side. if you get a reading on both sides, replace the ignitor. tom
leonidas64
#3 Posted : Sunday, May 1, 2011 10:41:12 AM(UTC)
leonidas64
easy way to check the oven igniter for voltage
kayakcrzy
#4 Posted : Sunday, May 1, 2011 10:45:43 AM(UTC)
kayakcrzy
Dude, this post was posted on 9-16-09!! Why don't you try one that was maybe posted????????? Today!!
