ScottW
#1 Posted : Wednesday, September 16, 2009 10:46:25 AM(UTC)
ScottW
dryer will start but will not heat up
#2 Posted : Thursday, September 17, 2009 3:56:34 AM(UTC)
Your Model Number seems to be missing the first three digits.
Here is a wiring diagram for a unit which has the same digits as you listed.
http://www.servicematters.com/d...0Sheet%20-%208528192.pdf
Put the unit into timed dry. Does the timer advance? On this unit (if I have the correct wiring diagram) both the heater and the timer motor use 240 volts. If it advances then you know that you have 240 volts. If not then odds are high that you have a power problem. Turn the breaker off/on slowly a couple times, better yet check it with a meter. Sometimes you can loose half the line without actually tripping the breaker.
Next top of the list items are the heater element and the heater's thermal fuse.
ScottW
#3 Posted : Thursday, September 17, 2009 9:21:43 AM(UTC)
ScottW
sorry first three numbers are 110
#4 Posted : Thursday, September 17, 2009 9:31:51 AM(UTC)
OK then the wiring diagram I supplied should be the correct one.
This unit is made by Whirlpool.
ScottW
#5 Posted : Thursday, September 17, 2009 4:52:16 PM(UTC)
ScottW
wiring diagram link does not work
#6 Posted : Thursday, September 17, 2009 5:36:04 PM(UTC)
Do not know what the problem is I tried the link and it works for me.
Tried it using Firefox and internet Explorer.
here it is again
