SRosie
#1 Posted : Wednesday, September 16, 2009 8:54:30 AM(UTC)
SRosie
Can someone offer step-by-step instructions on how to remove and replace the front air duct assembly (Part# AP3186270) for my Hotpoint/GE dryer (Model# NBXR453GV3WW). Thanks,
SRosie
sidfink43
#2 Posted : Thursday, September 17, 2009 4:20:11 PM(UTC)
sidfink43
Inside the door you will see some screws going from the top of the door jamp into the top of the dryer. Take those out and the top will come off. you can then take the front off by taking out the two screws that hold it on. If you disconnect the door switch, label the wires so you can get them on correctly.
You will then be able to replace the part.
Good luck.
