Im working on my neighbors dryer which is completely dead. I checked the door switch and the thermal fuse both seem to be fine, I do have 220v to the terminal block, now Im lost any suggestions would be greatly apreciated.
Check the push-to-start relay, the power to the motor and the motor itself. Post the results. Here is the wiring sheet. Here are the breakdown diagrams and replacement parts for the Whirlpool dryer Model LEQ9858LG0
