joe rogi
#1 Posted : 15 years ago
joe rogi
Elecrolux Or Fridgidare Professional Series Microwave
While Running Micrwave It Just Stopped And Would Not Come Back On ( Dead ) . So I Checked Breaker Box And Breaker Had Been Thrown. I Reset Breaker And It Started To Run Again
But ! This Time Then Exhaust Fan Would Not Stop Running.
The Fan Buttons Do Not Stop It. Only If I Unplug Bt When Ireplug Fan Starts Again .does Anyone Have Any Ideas ? ? ?
#2 Posted : 15 years ago
Remove the top grill and open the control panel. Check the hood thermal cut-out (#5 on the diagram) for continuity. It has to be replaced if it's closed.
If there is nothing wrong wrong then the control board most likely has gone bad.
- The hood thermal cut-out Part number: AP3768244
- The control board Part number: AP4358930
joe rogi
#3 Posted : 15 years ago
joe rogi
thanks i will give this a looking into.
i will let you know of my findaings
joe rogi
