brunerfamily5
#1 Posted : Wednesday, September 16, 2009 5:04:01 AM(UTC)
brunerfamily5
Went out to the refrigerator last night and light was off..thought that it was just lightbulb. This morning the refrigerator/freezer is not cold at all. Things in the freezer are melting. :(:confused::(
#2 Posted : Wednesday, September 16, 2009 5:32:07 AM(UTC)
Since you said you "went out" I am assuming that the unit is in a porch or garage.
Check that you have power at the plug and then check that the line cord is good to the machine. Not uncommon for a mouse to chew through a wire.
The compressor etc. are usually separate from the light, that is why I believe you have a power problem.
If it is more complicated than this a Model Number may help others help ypu.♦
brunerfamily5
#3 Posted : Wednesday, September 16, 2009 6:09:42 AM(UTC)
brunerfamily5
thanks I will check that. I did check to make sure that it was plugged in and that the fuse had not blown. Both were in check.
