Please help! My gas oven/range combo beeps without stopping. Sometimes its right after you cook and turn it off. Sometimes its in the middle of the night for no reason. The only way to stop it is to flip the breaker off. There are no error codes on the control panel when its beeping. Model listed above. Its a gas range/oven with a warming/cooking drawer.
Sounds like you might have a sensor that is malfunctioning. Try testing the temp sensor.
Originally Posted by: George.gill  Sounds like you might have a sensor that is malfunctioning. Try testing the temp sensor. Hey, and thanks for the reply. How do I do that? I looked through the parts manual and there is a part called a "Probe" I'm guessing that's it. Thanks again for your help
Yes it is the probe. Check the voltage coming in. Is it a single oven?
Actually the probe just senses. I believe it is attached to a thermostat. That could also be faulty. Check the voltage coming in. It should have a high limit. You could find that in the tech help manual.
Originally Posted by: George.gill  Actually the probe just senses. I believe it is attached to a thermostat. That could also be faulty. Check the voltage coming in. It should have a high limit. You could find that in the tech help manual. It is a double oven. The bottom is a Warming drawer/oven.I started with a google search that yielded this quick hit on a you-tube video My Frigidaire Oven goes Beep, Beep, Beep!!! - YouTubeIt shows my exact oven doing exactly what it has been doing. The text below said the guy replaced the Thermistor for the warming drawer/lower oven to fix it but my oven parts diagram didn't list that part.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi' I was cleaning the oven then I don't know why it started peeping. and show the word Prob.. and 32 orange numbers.. sometimes it stops then backs to peep
