spdkillz
#1 Posted : Wednesday, July 11, 2012 11:51:00 AM(UTC)
spdkillz
I am not sure which part to replace on my stove. The four eyes work when they are turned on. The clock works! I can push the button to bake on my stove and then set the temperature to preheat it. After i do this, i hear a click which is normal or seemed to be normal, but the element won't heat up. When I press the broil button, the same thing happens. Initially i thought it was the element, until i realized that neither element will heat up. I have been told a few parts, but then was referred to the forum so that i could see what a technician would tell me. Thanks for your time!
Simon / APP Team
#2 Posted : Wednesday, July 11, 2012 1:34:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the control panel and check(you will need the multimeter) the control board output as followed:
Between L1 and L2IN should be 240VAC. If not - check the outlet for 240VAC.
Next turn the bake on and check for 240VAC between Bake and L2 OUT. no voltage - replace the control board.
The clock/control Part number: 316207511
Here are the breakdown diagrams Replacement parts for Frigidaire FEF352AWG Frigidaire/electric Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
