Hi. Pretty sure my torsion spring (one or both) has failed. I guess I was lucky that the glass didn't fracture but this is maybe still a possibility w/ heat cycle? Anyways, I'm confused on the part#. I brought up the parts list here for this model# and I get: 38A Microwave door torsion spring - For stainless models. Left hand side. For the right hand side order AP3082257. No color tip. 49.5 - 54.5 lbs torque. Size: 3.50 inches long. Item Number: AP3137553 Manufacturer's Number: 4452395 made by WHIRLPOOL 38B Microwave door torsion spring - Right hand side. For the left hand side order AP3137553. No color code on tip. Item Number: AP3126615 Manufacturer's Number: 4452398 made by WHIRLPOOL What is line 38A trying to tell me about the right side? To use AP3082257 in preference to AP3126615 for stainless??? I asked APP via online chat and they told me for stainless that I needed: 38A 4452395 AP3137553 38B 4452398 AP3126615 left: WHIRLPOOL 4452395 Microwave Door Torsion Spring, AP3137553 | AppliancePartsPros.com [seems pretty clear, use 4452396/AP3082257 for the right] right: WHIRLPOOL 4452396 Microwave Door Torsion Spring, AP3082257 | AppliancePartsPros.com [seems to be for stainless but KEMC377KSS05 is not listed in the cross ref chart] right: WHIRLPOOL 4452398 Microwave Door Torsion Spring, AP3126615 | AppliancePartsPros.com [KEMC377KSS05 is listed in the cross reference chart] I'm fairly confused here. Can anyone clarify. I've owned unit since new, over 5 years and this is the first failure. I've read a bunch of reports of repeated spring failures and of door not having original tension after springs are replaced .... so if there are better springs to use I'd be interested in hearing, read some other threads where KitchenAid had recommended using two medium springs but validity of advice was questioned.
Rank: Administration
Groups: Administrators
According to Whirlpool the 4452395 and 4452398 are the correct springs you will use for your model.
Originally Posted by: Adam / APP Team According to Whirlpool the 4452395 and 4452398 are the correct springs you will use for your model. Thanks .... so what is the deal with 4452396/AP3082257 It's all very confusing.
