Lets talk dehumidifiers. 2 dehumidifiers and both the fans and compressors work however they both will not produce any water Help me please with my guess that the sealed system is the issue. Either a possible leak or a recharging needs to happen? No frost pattern around the evap at all when running
Thank you for your answers appreciate it
Yes this sounds like a sealed system issue, you need to check for leaks around any solder joints or get a leak meter and check and get your self a compound gauge and add some freon and look for the frost pattern if it stays your good if not attempt to evacuate than and recharge.
