When we tryto dispense water on the freezer door Water also comes down ice maker chute and runs into ice bin and on down over products in freezer making a big ice mess. What has gone wrong ?
Try checking the water valve to make sure you have a tight connection
Pull the back cover off and remove the wires that go to the plug that goes to the icemaker water solenoid(the one with the 1/4 water line). Have someone dispense water. If you now still get water in the icemaker, replace the water solenoid.
Post the correct model #.
Richappy stay out of my way go find your own problems to fix its not very professional to butt in thank you.
