PILLCOTEX
#1 Posted : Wednesday, January 23, 2008 8:02:11 PM(UTC)
PILLCOTEX
I have a maytag dishwasher and am having trouble with it completing a cycle. i can program it to start, but when it goes to start, the motor will give a quickspin (about 1/2 a turn) then it will stop. Then it will sit there and keep starting like i described until i cancel it or open the door. I pulled the circuit board out and it has two highly heated up resistors labeled R301 and R302. the circuit board is discolored at those connection sites. I realize i have to replace that, but the question is..... What made those resistors blow? ANY help will be appreciated ! ! !
kawfeeman
#2 Posted : Thursday, January 24, 2008 6:48:59 AM(UTC)
kawfeeman
can you check motor start relay ?
PILLCOTEX
#3 Posted : Friday, January 25, 2008 12:34:24 PM(UTC)
PILLCOTEX
Looks like the start relay is built into the circuit board (small blue box 1/2"x1")I do not know how to check it without specs on voltage....... the only other control is the overload switch.. Think that would do this?????
Phil
BeginnerGuy
#4 Posted : Thursday, April 3, 2008 6:11:19 PM(UTC)
BeginnerGuy
Phil (Pillcotex):
Did you figure out what caused your dishwasher to go bad? I have almost the exact same model...a little older. I think the same resistors are burned. Just wondering if you were able to diagnose it.
Thanks.
ccarm
#5 Posted : Friday, April 4, 2008 5:53:00 PM(UTC)
ccarm
Sorry, I cant help with your problem, but I'm looking to by a used door panel,kick plate and the plastic cover for the controls for a MDB9150aws.
I'm converting a mdb9150awq to a mdb9150aws. Anyone ?
BeginnerGuy
#6 Posted : Tuesday, April 8, 2008 7:07:24 PM(UTC)
BeginnerGuy
Quick update...for my MDB9150AWW Maytag...I just installed a new control board this evening. Not too difficult. I made a picture of where the wires plug in before I removed the defective board. This was real helpful when putting the new board in.
Based on suggestions from others, I checked the wiring harness for defects. I found that there were a couple of wires where the plastic sheathing was cut through, but the copper wire looked unharmed. I found this down where the door hinges. It looks like a metal part from the door had been cutting into the wires somewhat. I'm not sure if this is what caused the control board to fail. Anyway, I used some electrical tape to tape up the wires, and then also to cover up and sharp metal edges.
When I was all done, I turned the power back on. Works like new! It is now on it's 2nd wash cycle.
poija01
#7 Posted : Sunday, January 4, 2009 5:12:56 AM(UTC)
poija01
BeginnerGuy,
Where did you find the replacement circuit board? I have the same problem down to the bare wires. I can't find the circuit board online anywhere.
BeginnerGuy
#8 Posted : Sunday, August 23, 2009 1:58:13 PM(UTC)
BeginnerGuy
I bought it online from AppliancePartsPros.com
Originally Posted by: poija01 Go to Quoted Post
BeginnerGuy,
BeginnerGuy
#9 Posted : Sunday, August 23, 2009 2:02:14 PM(UTC)
BeginnerGuy
MDB9150AWW
click on the link for the diagram. You can purchase from AppliancePartsPros.com.
The new circuit board is still working fine.
