fyrman1899
#1 Posted : Sunday, July 8, 2012 8:22:34 AM(UTC)
fyrman1899
need some help installing two new parts - first is a white colored timer control lever part number GE 12X324 that appears to have some control over the soap dispenser arm, which is the other part that i ordered. That one is black in color, and is part number 828 in the door schmatic. I CANNOT determine what activates the white arm which appears to release the black arm to open the soap cup. ANY HELP would be greatly appreciated!!!!
#2 Posted : Monday, July 9, 2012 1:56:23 AM(UTC)
Here is a link that may help
http://www.applianceaid.com/dis...-dispenser.php#ge-closed
The bit at the bottom that starts with "My GE"
The door is actually run by the cam on the timer through the two linkages you mention.
