Hi! I'm looking to help my parents replace the inner glass for their KA Superba oven. Can someone please help direct me to a replacement part as well as directions on how to replace it? Thanks so much, in advance!!:)
Here are your parts Replacement parts for Whirlpool KEMS377DBL2 27" BUILT-IN ELECTRIC DOUBLE OVEN | AppliancePartsPros.comThe inner door glass is Item 3 in Section 8. Click on its picture fore more info. There is install info in the Q&A section. Remove the oven door from the unit. Your operators manual should tell you how. If you do not have the manual you should be able to download it from either the Whirlpool or Kitchenaid site. Place it outside down on a towel etc. on a table or counter. Handle over the edge so the door lays flat. Then remove the screws and replace the glass. |
THIS FORUM IS DEAD!!!!!!! |
Thank you SO much, Denman! Your help is much appreciated.
