AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
freezer dripping defrosting, coils defrosted still not working fan running loud
2 Days Ago Ice Cubes Stuck Together, Freezer Not Cold Enough Defrosted The Coils Behind Panel. Turned Back On Freezer Never Got Below 25 Degrees What Next...? Fan Below Ice Maker Sounds Loud Replaced That Fan 2 Summers Ago
Here are the parts includes a wiring diagram. Replacement parts for Maytag MSD2756GEB REF - SXS/I&W | AppliancePartsPros.comWhy did you defrost the evaporator coils? Were they heavily iced/frosted over? Or did you assume that a defrost problem was the most likely cause? Is the compressor running continuously? Is the condenser/compressor fan running? Is the evaporator/freezer fan running? Are the condenser coils clean? Also the vents, front and back. |
THIS FORUM IS DEAD!!!!!!! |
