happyroader
#1 Posted : Wednesday, July 4, 2012 8:24:48 PM(UTC)
happyroader
need help resetting touch pad stuck on F1 even after turning off circuit breaker for 15 minutes
#2 Posted : Thursday, July 5, 2012 4:19:41 PM(UTC)
The "F1" error code points to the control failure. The correction is to replace the oven control board. If you need the correct part number, post the color of the keypad.
happyroader
#3 Posted : Monday, July 9, 2012 9:50:32 PM(UTC)
happyroader
Thanks for help..It fixed it's self when I used the oven for dinner. The F1 went away and hasn't come back..I just hope the power doesn't go out again.
Guest (4)
