dlongnecker
#1 Posted : Monday, July 2, 2012 9:01:47 PM(UTC)
dlongnecker
I've been fighting my ice-maker for the last couple weeks. I thought I had it, but this evening, we discovered a lake in the kitchen. THought it was they dishwasher, but we opened up the freezer door and the dam opened. I could tell water was flowing from the ice maker.....guess it isn't sensing it is full and is just filling up?
What part should I order....or might it be something else?
nobull1466
#2 Posted : Tuesday, July 3, 2012 3:34:06 AM(UTC)
nobull1466
Two possibilities, if water is constantly flowing out of your icer maker then I would check the water valve (W10408179). It may have dirt in the valve causing the valve to stay open. If the water has stopped then I would look to the motor module (WPL8201515). The fill is a "timed" fill. In other words, water would flow into the ice maker for approx 6-8 secs then shut off. If that is not happening the module may be bad.
