AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer will heat but not spin- kenmore 70 series model
I have a Kenmore 70 series! The dryer starts and heat but it does not spin. I suspect a broken belt.
If it is a broken belt.
1. How do I access the belt on the dryer? (I went through the back an there was more stuff that I needed to dismantle, so before I proceed do I need to access it from the top) Are there any diagrams that I can look at.
2. If it is a broken belt what belt do I need to purchase.
Originally Posted by: abengoa I have a Kenmore 70 series! The dryer starts and heat but it does not spin. I suspect a broken belt.
2. If it is a broken belt what belt do I need to purchase. I have a petty good idea but 70 series is not the model number. List the complete model. It will start with 3 numbers followed by a decimal point with more numbers after it. Check out both of these videos. Between the two of these you should get a pretty good visual on how to get in and out of the dryer. Belt replacement YouTube - DIY Home Repairs. Replacing Your Dryer Belt Roller replacement YouTube - Whirlpool Dryer Repair video
Dryer Repair
