when i power up oven i have no display at all and nothing else working can anyone help?????
Here are your parts, includes a wiring diagram. Replacement parts for Frigidaire FEB24S5ABB Frigidaire/wall Oven | AppliancePartsPros.comSince nothing works (I am assuming this includes the oven light) it sounds like a power problem. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
