edgecknight
#1 Posted : Monday, September 14, 2009 10:52:55 AM(UTC)
edgecknight
My dryer will not start. I think it might be my relay to start switch. Is there any way to test it? Or could it be something else? The dryer ran fine up until now.
#2 Posted : Tuesday, September 15, 2009 3:38:41 AM(UTC)
Cannot find any info using the given Model Number so here is a good site with troubleshooting help
http://www.applianceaid.com/dryers.html
Try to find the wiring diagram may be pasted on the back cover or in the control console.
Could be a number of things.
I am assuming it is electric.
1. Check that the unit is getting the correct power 240 volts from L1 to L2 and 120 volts from L1 to Neutral and L2 to Neutral. Try turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker
2. Could be the door switch is not closing or is toast
3. Most units have a thermal fuse that kills power to the motor if it blows.
Often a white device on the blower assembly. This can also be checked by unplugging the unit, removing the wires from the fuse, taping them together so they cannot short to the frame then giving it a try. If it is blown replace it ASAP as it is a critical safety device. If it is blown be sure to clean/check the blower wheel and the vent system.
4. The relay coil can be checked for continuity with a meter also if it is the type that is an integral part of the start switch the contacts can be checked.
There are a number of other things that can cause a no start.
