I just received a new spray arm assembly. How do I get the old one out?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
If you take a close look at the bottom part of the spray arm assembly, you will see a thread.
Most likely it should be screwed into the pump connector.
I see that. I cannot get the old one out. It won't budge.
You are going to replace it anyway. If it does not come out - brake it in pieces.
