Carl 66
#1 Posted : Wednesday, June 27, 2012 2:45:56 PM(UTC)
Carl 66
The motor that spins the glass plate is not working. Trying to locate a part number for it.
Carl
#2 Posted : Thursday, June 28, 2012 3:30:24 PM(UTC)
Hi Carl,
Before you will order the motor, verify if there is 21 VAC to the motor while the control calls for heat.
If the voltage is correct, replace the motor.
If the reading is incorrect, replace the control board.
- The turntable motor Part number: WB26X10038
