bubbatippy
#1 Posted : Wednesday, January 23, 2008 12:04:03 PM(UTC)
bubbatippy
Groups ready for retrieval: Registered
I have oil leaking into the wash tub and believe I need to replace seals (my washer is 17 years old). The problem is I cannot see a top cap or any
way to remove the agitator. How is this done on my unit? Thanks.
#2 Posted : Thursday, January 24, 2008 12:18:27 PM(UTC)
Remove the dispenser (#1 on the agitator break down diagram), remove the screw (#6 on the agitator break down diagram) and lift the agitator.
- The part number for the drive bell/seal kit is AP170657
Here are the break down diagrams for the Speed Queen washer Model NA4521
rwegner
#3 Posted : Monday, February 2, 2009 10:37:41 AM(UTC)
rwegner
On my Speed Queen Mod. No. NA 4521, there is no dispenser. There doesn't seem to be a way to get to the bolt #6 through the agitator #7? Help!
#4 Posted : Monday, February 2, 2009 10:45:36 AM(UTC)
Did you try to pull the agitator up? It could be very hard.
#5 Posted : Monday, February 2, 2009 2:25:37 PM(UTC)
Put a rope under the agitator, and pry it off with a 2x4 and the top as a lever.
Removing agitator, GE washer (Washer Repair)
by tealbingy 1/28/2011 11:51:33 AM(UTC)
Removing Agitator (Washer Repair)
by dap 9/21/2010 9:00:54 AM(UTC)
removing agitator (Washer Repair)
by gregdcwirth 4/2/2010 5:52:53 AM(UTC)
by rmullar 10/11/2009 2:39:52 PM(UTC)
by james429 11/19/2008 12:25:15 PM(UTC)
Removing agitator (Washer Repair)
by Jeffrey M. Quirante 6/22/2008 12:33:33 PM(UTC)
by Yago 4/23/2008 3:06:04 AM(UTC)
by george m 4/1/2008 2:48:00 PM(UTC)
