carolynswhirlpool
#1 Posted : Monday, June 25, 2012 8:51:29 AM(UTC)
carolynswhirlpool
Water and ice not coming out of door. Lights on door working but no sounds when pushed. Light switches from crushed to cubed. Will make ice if water dumped in tray but didn't fully dump probably cause not enough water.
Simon / APP Team
#2 Posted : Monday, June 25, 2012 10:36:20 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Looks like you may have two unrelated problems.
First the icemaker doesn't work and the dispenser not working.
At the bottom of the freezer door hinge you will find the wires going into the hinge. Check this wires for damage.
Fill up the icemaker manually and see if it will make ice.
Thank you. Post the results.
Simon.
