I have had several problems one was draining which I fixed then water was not filling enough water into the tub fixed bad water supply valve now the unit fills durring the firs cycle but will not fill durring the other cycles. The unit has a circuit board 8564542 and I think it has a bad relay or do all the fill cycles fill from the same relay? I'm ready to get out my shotgun (mabye it will drain faster) I thank you for your input. Respectfully Rick
THIS FORUM IS DEAD!!!!!!! |
